Guys, This is getting to be a real headache.
I have taken everything off one piece at a time to discover where the vibration is coming from. I took everything off the tail except the shaft. At certain rpm's you can see the shaft start to vibrate but very very small amount and only at about 1/3 throttle then it goes above 1/3. I have gone all the way back to the motor, taking one piece off at a time. The only thing i can think of left, is the motor is unbalanced. Shaft looks straight on the motor. Main shaft is straight and tail shaft too. All have been changed three time to make sure its not them. main gear replaced. Belt tention set at different tensions. Still have the same issue. Only thing left is to change the motor if you think that could cause the problem.
Check the video to see what you guys think.
Cheers Lee
Cheers Lee
