ChainsawHeli
Hi and thank you for the help. I bought a 450 L Dominator off someone who never set it up. It is all set up now with a AR7200 and everything seemed to be fine. The only problem I'm having is the tail. Firstly the tail servo only moves a tiny amount in each direction, and I have set it up several times with the end points. I even tried setting it up with end points beyond the actual range and it makes no difference. In flight mode it only moves in half of it's range. The only way I could work out to make it work was to use a longer servo arm.
The second issue which I am sure is related to the first, is during the first few flights, there is very little tail control, and I am constantly compensating for every movement. It is pretty scary when the tail keeps swinging in all directions and I am keeping a constant compensation to keep things under control.
As a backnote, I flew a lot (450's) before kids, that was 12 years ago so I am sure to be a little rusty with the set up. This is my foray back into the sport, a little scary foray so far.
I would appreciate any help, Cheers Chris
