  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Motors 3s To 4s
Discussion in 'Electronics' started by Fly-n-Low, Oct 29, 2019.
< Clearance issue? | Battery Choices? >
  1. Fly-n-Low
    Fly-n-Low New Member
    Oct 27, 2019
    6
    0
    1
    Gender:
    Male
    NE Louisiana
    3S 480 motor, upgrade to a 4S capable 35A ESC. So will the motor burn running 4S?
    Fixed wing, sport flyer.
  2. Tony
    Feb 21, 2011
    36,844
    1,431
    113
    We are going to need to know exactly what motor you have to answer this question. If you can post a link to the product, we can let you know if it will handle 4s or not.
  3. Smoggie
    Smoggie Well-Known Member
    Dec 14, 2015
    2,358
    125
    73
    Gender:
    Male
    Aberdeen, UK
    As a general rule the motor will be ok with the increased voltage but you will most likely have to run a smaller prop, otherwise the amps will be too high and it could burn.
    Like Tony said, motor specifications required and prop details
  4. Fly-n-Low
    Oct 27, 2019
    6
    0
    1
    Gender:
    Male
    NE Louisiana
  5. Tony
    Feb 21, 2011
    36,844
    1,431
    113
    Wow, there is absolutely NO information on that motor on that page. Very interesting.
    If this were me (and I'm not saying you should do this), I would put a 4s pack in it and fly it for one minute to test the motor temp. Of course I would be lowering my prop since the rpm will be going up. In doing this, I would risk losing a $50 motor. If you do try this, just know that this $50 motor could go up in smoke.
    Also, make sure your ESC can handle 16 volts as well. If it can't, it could burn out and in rare cases, push full voltage to the servos which would not be good.
    Fly-n-Low likes this.
  6. Admiral
    Admiral Well-Known Member
    Mar 2, 2014
    2,057
    125
    73
    Gender:
    Male
    Occupation:
    Information Technology (Retired)
    Brisbane, Australia
    Found a discussion on this motor, seems everybody is have the same issues with Specs, comments are plagiarized not mine.
    From a guy who used a 4S motor.
    It can be used with a 4s, but you must reduce the prop size so that you don't over-amp the motor and burn it up. And no, it definitely is not a 480 watt motor. I rather like these motors myself, lots of guys don't however.
    Then comments by a guy who had tested the motor, the page with the data was no longer available.
    It would seem that it is, at the most, perhaps a 240W-250W motor:
    Hope this helps.
  7. Fly-n-Low
    Oct 27, 2019
    6
    0
    1
    Gender:
    Male
    NE Louisiana
    Thanks guys! I do have a spare motor with a broken shaft I can use for parts if it smokes.
  8. Jamess
    Jamess New Member
    Nov 27, 2019
    4
    0
    1
    Gender:
    Male
    Los Angeles
    Yes, although suppliers don't support this, I also tried to use my 2s 5200 and 3s 5000mah in series last time, but I didn't do it again
Share This Page
