I just did a repair on my 300X after having what I can only assume was a minor brain seizure at the bottom of a loop. I swear, why would I have gone full negative collective at that moment? Something is seriously wrong with my noggin.
Anywho...
I've had pretty good luck with the stock wooden blades so far, but this time I spun it up and it very nearly wrecked itself it was vibrating so bad. I spun the head by hand to see if it looked like a bent mainshaft and saw nothing wrong. Took the blades off and spun it up and no vibration issues (except in the tail, that's a separate, higher frequency vibe though).
So I put the blades on the scale. Wow. They were nearly 50 grains off from each other. I've never gotten a set this far out of balance before. In fact I haven't had a need to balance stock pairs of blades until this point.
Checked spanwise CG and they were within a mm of each other that way. Can only figure someone at the factory grabbed the wrong one when packing them up.
I balanced an unmatched pair of blades last week using scotch tape, since they were only 10-15 grains or so off from each other. But 50 grains, that's a lot of scotch tape. So I ended up using electrical tape this time. Ended up practically reskinning the light blade, as seen in this pic.
The central pieces are duplicated below the blade. The one piece off to the right was an attempt to adjust the COG. Too small a piece vs the weight of other tape. So I ended up with the cog moved a mm or so inward toward the root. Should be fine.
Will be spinning it up today.
Anywho...
