GreekRotorHead
Hi guys, I have recently broken in the engine of my new buggy. I have tuned the high and low needles to keep operating temperatures at about 110 Celsius degrees. My problem is that most of the times especially when the engine is cold, when I apply a little bit of throttle the engine dies. I have to apply the throttle gently enough so that the engine won't die. When the engine reaches operating temp there is no problem at all. But every single time I start the engine I have this problem. A bit of throttle and the engine stops. What may be the cause of this? Is the low end needle too rich? Or the idle screw needs adjustment? And something else. If we assume that the throttle range is 0-100%. In what percentage does the low end and high end needle works? Is the low end needle from 0-50% throttle and the high end from 50-100% ? Or the low end needle does all the job from 0-80% throttle and the high end needle starts its operation from 80-100% throttle? I have heard different aspects for this.
