Hello Teachers,
My GARTT DFC replacement arrived. It fits mechanically not a problem, but :
1) The quality, is not exciting - in particular the plastic rod connectors, they don't have the "A" and come off too easy...
2) The 3 pushrods from the lower Swashplate to the servos came at a setting too short for a swahs levelling, considering that the elevator control can NOT be adjusted, the other two need to follow it.
3) In all the Align Trex 600 DFC manual I found, the length between the plastic connectors needs to be set to 15mm, but to get the swash level, I need to get to at least 23mm. Or am I looking at the wrong manual?
4) After installing the new unit in the machine, I have a vertical "Play" of 1mm which I am of course not happy about. Do you think I will need to find a Shim washer to prevent it?
Looking for some help please
Cheers
