Aomway Commander V1 Goggles Updated Version Discount Code
Author Rating:
5/5,
    When the Aomway Commander V1 goggles came out, they filled a huge hole in the market that needed to be filled. Quality goggles at a friendly price. But now, they have made them even better!
    They now come with not only the patch antenna but also the SMA Aomway Antenna that is circularly polarized. There is now writing on the case so that you can see what each button does as well as what each port is, but now, they have also put in detents on the IPD adjustments to keep your lenses set where you want them rather than just flopping around.
    From the very fast channel search, to the 48 channels, to the very sensitive Diversity receivers, these are absolutely fantastic!!!
    And for a limited time, you can get these goggles for $279 with the discount code below. Smokin' deal on awesome goggles!!!
    Aomway Commander Goggles - AOMWAY Commander V1 FPV Goggles -$312.99 Online Shopping| GearBest.com
    Coupon Code - GB11.11Deal14
    Aomway Antenna RP-SMA - AOMWAY 5.8G 3dBi RP-SMA Male Four Lobe RHCP VTx/VRx FPV Antenna
    90º Adapter for Antenna - SMA Male to RP-SMA Female Right Angle RF Adapter Connector
    90º Adapter for Patch - 1 PC SMA Male To Female Adapter Right Angle 90 Degree
